Greetings, I purchased a VSP Labs Gold Series Trans Mos amp a while back and luckily it's in pretty decent cosmetic and functional shape. I started looking for technical info on this unit, but like most, found little. At this point I'd like to mention a little about the designer of this amp - Juan Velazquez. Apparently Mr. Velazquez passed away last summer - his obituary can be found here: https://obits.mlive.com/us/obituaries/annarbor/name/juan-velazquez-obituary?id=52550447
Even though VSP Labs was located here in Ann Arbor, MI, where I currently live, I was surprised to find that at the time of his passing, Mr. Velazquez was living in Saline, MI, barely 10 minutes from my house. I wish I had known this long before this week when I found out. I almost certainly would have attempted to contact him. Not just to inquire about some of the VSP amp technical info that seems to be much needed, but to also give respect where respect is due. It's not often that audio engineers of note are found basically living right next door. I was saddened to read that Mr. Velazquez had passed, but remain grateful for the contribution he and his crew made to the pantheon of quality audio components we all enjoy. RIP.
As I mentioned, the VSP Trans Mos Gold Series (200W @ 8 Ohm) I have is in pretty good condition and I've read several posts from those with non working amps that have no idea about where DC offset, bias and the like, should be set once they do get their amps safely powered up. I've yet to find docs that specifically show or denote that they are for the Gold Series, but there is a bit of documentation online, and here in the AK archives, for the Trans Mos 150 (150W @ 8 Ohm) - some of which may transfer to the Gold Series as well. Having compared my amp to images of other Gold Series amp there also seems to be multiple revisions of this and the TM 150 amps - as is common for just about every amp out there. When I decided to check this amps functionality the first thing I did was power it up on a DBT - it passed. Then I checked the DC offset at the speaker terminals - and after about an hour of on time with no load, my amp measured:
[119VAC Supply]
Rt Ch: -164mV (Pos. lead to Pos/Neg to Neg)
Lt Ch: -111mV (Pos. lead to Pos/Neg to Neg)
The VSP TM150 Instruction manual states; "DC Output Offset: +/- 50mV or less, typical 5 - 10mV, internally adjustable." I've found no info yet about DC offset for the Gold Seris amp and don't have the bonifides to make assumptions about what it's offset should be for this amp. Any input and opinions would be appreciated.
There are only 2 trim pots per amp board in the amp section of any of the available TM150 schematics. There are 4 trim pots on most of the amp schematics, but I believe that two of the trim pots are on, and for, adjustments at the NE5532AN OpAmps on the input board - one trim pot pair per chip, per channel. [US Patent diagrgm cir. 1984] My input board also has a TL072CP, low-noise FET Input OpAmp - which may be part of the "T-Sense" (clip/mute) circuit. A circuit that exists on both versions of the TM amps but the TL072CP isn't on the TM150 schematics. One TM150 schematic shows an "RTS" (trip sense) variable resistor - so I believe that that is what the 5th trim pot on my TM GS input board may be for.
The two trim pots on the TM150 schematic's amp section are connected to the two Differential pair's emitters (2N4401 / 2N4403) on the amp boards.
There are 4 trim pots on each of my TM Gold Series' amp boards; The amp boards are PN: [L] 10-0255B1 / [R] 10-0258B1. I assume that two of the trim pots are for each of the differential pairs that also exist on the TM GS boards, but I'm not sure as yet what the other two are for.
It seemed safe to take the amp off of the DBT, so I did, and then I pulled each of the two 10A fuses that are each of the amp boards, one at a time, and measured current. The two fuses, when looking at the amp boards face on are: Left side Negative supply and Right side, Positive supply.
The current was measured after the amp had been on at least an hour;
Right Channel: Negative supply Fuse: 282mA Right Channel - Positive supply Fuse: 280mA
Left Channel: Negative supply Fuse: 351mA Left Channel - Positive supply Fuse: 351mA
These current readings settled down to these measurements within a few minutes, stabilized quickly, and remained stable and consistent.
I decided to hook the amp to a load and scope and run a signal through it. Even with my limited knowledge I'd consider the results encouraging. No odd artifacts or oscillations and a pretty balanced output. This scope is capable of displaying other measurements, which I should have initiated, but I just wanted to see what I'd get - DC and current measurements being what they are.
I figured it was OK to run program material (music) through the amp, which I did, and the results were fab. It sounds great. At moderate volume for about an hour the heat sinks are only just slightly, but evenly, warm. I believe that do much else would require me to seek the assistance of those that have a better idea than I do of if and how to proceed with any adjustments or service. With no specific TM Gold Series schcematics to go on I kind of feel comfortable leaving this amp the way it is, but at the same time it can obviously be risky leaving an amp built around 1983 to it's own designs.
I hope that not only will this thread and these measurements help anyone else working with a VSP Labs Trans Mos Gold Series amp, but also invites those interested in and experienced with working on quality amps with little documentation and a large fan bases, to offer their valued opinions. I'm really interested in knowing what people think in regard to dealing with an amp in this condition and of these circumstances. I just finished restoring a pair of Infinity Quantum 3 speakers which have been looking at this amp over my shoulder and drooling every since I took it off the shelf. Their favorite food, I'm told, are high current amps that'll laugh at a 2 Ohm load. I'm beginning to become worried that I'll come into the shop one morning and they'll have hooked themselves up while I was sleeping! Things are cool for now, but I look forward to any and all opinions, info and recommendations. I'm eager to get it back into service, which I'm sure, is something Juan Valezquez would be happy to hear.
[119VAC Supply]
