What am I missing? Voltage doubler for DHT
Thinker
Hi Everyone,
I recently built this circuit: http://www.dmitrynizh.com/moondog-choke-dc-doubler-compl.gif
it's supplying 12.4 volts DC but, the filament looks pretty bright compared to the other channel that I left AC for comparison, and R2 the 0.15 ohm resistor got so hot it started to glow, which I don't understand why only one of the 0.15 resistors got hot, I believe it was the negative one. The 6B4G filament is suppose to draw 1 amp so if V = I x R then shouldn't 1 x 0.15 = 0.15 volts? and then P = I x V 0.15 volts x 1 amp equal 0.15 watts? So why is my 1 watt resistor glowing like a light bulb? I feel like I'm missing something.
I would check the voltage at the tube filament, also you are supposed to drop 6v instead of 2 1/2 v
A 2a3 also draws 2.5 amps for filament current
I was wondering if that's where I screwed up, that the reduced current draw caused the circuit not to drop enough voltage. My filament transformer is center tapped, as a simply solution could I just use that instead of changing the resistor values? If I did change the resistor values would I just increase them by 2.5? And I still don't understand why the 0.15 resistor was dissipating so much power.
I suggest you post the entire circuit, as built, and label it with measured voltages. Your original post isn't clear enough to eliminate guesswork.
well... if the center tap were grounded, it would short the doubler.It may work without the doubler, and drop the 2v of rectified 6vac (about 8v)
If you used 1/2 of the transformer and doubled it, it would be the same as using the whole transformer, with the negative effect of drawing twice the current from that half of the winding.
