What is this beast?
Yeah, true; worth $15 even if it doesn't work (long as one has a use). Doubt it has any unobtanium parts.
I believe it's 1.5A. The numbers are too far apart to be 15A, when you compare the spacing to the 35V numbers.
These old power supplies pop up at hamfests and radio swap meets all the time. The tube ones are at least good for parts, but that one is probably solid state and there’s not a lot you can pull off it. I quit picking them up at pretty much any price.
have to be careful with solvents on plastic lenses, some plastics react poorly and go cloudy. Some go badly with alcohol, some go badly with petroleum based.
