davidguilbault
Perusing the Bargain Bins
Hi folks,
I am going to do some home recording of my songs. I will have two Presonus TubePre microphone preamps. But, I understand that the Chinese tubes that come stock in those should be replaced for better performance. I know absolutely nothing about tubes.
Which 12AX7 replacement tubes should I buy for warm vocals?
Here's the blurb about the preamp on the Presonus site:
"... the TubePre is definitely all-pro, starting with a dual-servo (no capacitors) gain stage that lets you boost the program signal to smoking hot levels without significantly increasing the background noise.
The 12AX7 vacuum-tube-based preamp includes a Gain control and a Tube Drive control that lets you decide how much signal to put through the tube. You get 48V phantom power, a 80 Hz high-pass filter, -20 dB pad, and polarity-reverse switch, just like with the big preamps. And of course, the TubePre delivers the highly prized tube warmth we all love. It even sports an analog, backlit VU meter.
The TubePre is more than a mic preamp, though. Thanks to separate instrument and mic inputs, it also serves as a dynamite direct box (DI) for guitars and basses. And it’s small enough to carry almost anywhere, although you also can rack-mount it using our optional 3UMR rack adapter."
Thanks for your help. Cheers for now. David.
