Which cartridge to keep ? Stanton or AudioTechnica
yurka77
Well-Known Member
I have these 2 brand new carts and want to only keep one for my use. Which one you feel would be better for my Technics SL-1210 MK5 table with CJ phono stage.
Audio-Technica AT-OC9/III or Stanton 881S ? thanks
Yes, the Stranton 881S with its original stylus is NOS, unopened, never used. My CJ tube phono stage supports both, MM and MC.
If you don't own any other cartridges, and want to own only one cartridge, go with the Stanton. I like being able to quickly and easily switch styli for beat-up records. You can get an inexpensive aftermarket stylus for the Stanton so you don't ruin that Sterohedron with a bad scratch.
thanks for all great advice guys, this is why I love this place. I dont think i can keep both of them. I also have Denon DL-110 as every day use so wanted to keep one of the other two as a special occasion treat but only one
You need both, use the Stanton when the AT stylus needs to be replaced as it is a rebuild not a plug and play
Given your table / arm I would think the AT cartridge might be a bit better match from a compliance perspective. The 881S is high compliance and best performing on a low mass arm with low VTF. Both are quality cartridges so no bad decision either way.
It would take a spensive SAS replacement to get up to snuff and it would only come near the original performance - but not quite.
Jico doesn't even make a SAS for Stanton carts AFAIK. They only make bonded ellipticals and a bonded Shibata. I asked if they could make a SAS for a Stanton a few years back and the answer was "no".
