A fair write up and some of the reasons why.........
Quote:
Single driver speakers are not for everyone. I want to make this clear at this point, because the last thing I want to do is have a pair of speakers returned as "unsuitable".
Single driver speakers are most suitable for the more intimate genre and at moderate volume levels. This includes solo voice, small group jazz and 18th century classical and chamber music. For these genre, single driver speakers are superb. You will hear nothing better. They also do classic rock pretty well as long as the volume is kept to reasonable levels. By reasonable, I mean ~80dB at the listening position. (I set my LT-2000/DX3's 8 feet apart and my chair 8 feet back.) Now, if you are into heavy metal or want Mahler symphonies at concert volume, I suggest that you look elsewhere. You will be disappointed and I have to eat shipping costs and try to unload a custom pair of speakers at as little loss as possible.
Why Single Driver Speakers?
Single driver speakers have a unique sound. That sound comes from a lack of a conventional crossover. In a two-way speaker, the acoustic phase of each driver rotates in opposite directions around the crossover point. While the combined phase may be correct at the crossover point, away from that point, the phase will be constantly changing. Why is this important? The human ear/brain is designed to locate sounds primarily by phase. We are very sensitive to phase in the 300-3000Hz range. Outside on this range, sound location becomes increasingly difficult, but within this range, if the phasing is messed up, the sound stage lacks precision and depth. A normal two-way speaker has the crossover point in the middle of 1500-2000Hz range, which is smack in the middle of the frequency band where humans are most sensitive to phase changes. By not having a crossover and the attendant phase problems, a single driver speaker sounds much more natural.
A good single driver speaker is more articulate and detailed in the bass and midrange that a multi-way speaker. Because the driver in a singe driver speaker must work up to 10kHz and beyond, the cone is much lighter than the cone of a comparably sized driver in a multi-way speaker that is crossed out by 2kHz. Less cone mass means faster response to the electrical signal and better transient response. The lighter cones also promote higher efficiency. While my speakers don't qualify as "high-efficiency", all except the FTA-2000 are rated at 92dB/w/m or better, making them good matches to all but the smallest tube amplifiers. (Don't worry, they work great with high-powered solid-state amplifiers too.)
http://www.geocities.com/rbrines1/
The key to SDFR systems is coherence. If that means little or nothing to you, then go elsewhere for your music. Some listeners are sensitive to timbre and timing while others are not. Some are confounded by the sound of conventional ported systems while others are not. IMO you have to decide what it is you are trying to eliminate from your music before you are a good candidate for a SDFR. You might find a two way system with a very simple HP filter alone to be closer to satisfactory when compared to a SDFR with the two way offering slightly greater (measured) high frequency extension and almost certainly a wider sweet spot for listening. However, the phasing issues mentioned on Bob's web page will always exist with any crossover and it requires a designer who is thinking outside of the normal conventions of consumer loudspeaker design to make a simple two way system work well.
Beginning explorations of SDFR's need not be expensive though the best of the bunch can represent a substantial investment given the conflicting requirements placed upon a SDFR.
Don't limit yourself to the Fostex line, there are more than a few SDFR's to choose from (
http://www.audience-av.com/parts/A3.php). Do some research before investing in any driver. This is a particularly nice SDFR that I have heard in several systems but it sacrifices sensitivity for smoothness (
http://www.creativesound.ca/details.php?model=FR125SR). The size of the driver will be one consideration with obvious trade offs as you go between smaller and larger diameters.
Sensitivity is another consideration and currently many SDFR's are being built to suit the low powered SET and T-amp crowd (which also suits the character of a SDFR quite well - better IMO than a solid state, high powered amplifier would in most cases). However, if high sensitivity is not a requirement for your system, then you can trade off some other qualities by running a slightly lower spec'd unit. No matter what sensitivity spec you choose the efficiency of the system is generally higher than that of a two way since no energy is lost in the crossover components. System impedance remains quite constant in a SDFR so you are unlikely to stress the amplifier and that high current transistor amplifier will be out of place with a SDFR.
Most of the lower cost SDFR's (Fostex in particular) will show a rising midrange response which you must deal with in some manner. Some listeners choose to insert a baffle step correction network (
http://search.yahoo.com/search?ei=utf-8&fr=slv8-hptb5&p=baffle step ...) while others simply deal with the position of the speaker within the listening environment or by manipulating the baffle dimensions. This approach would lead you to the possibility of an open baffle SDFR (
http://search.yahoo.com/search?ei=utf-8&fr=slv8-hptb5&p=open baffle ...).
