Will Bi-amping improve SQ on low SPL ?
qguy
Speakers Acarian Alon IV, 3 ways with 12 inch woofers, 87dB, 3 ohms min
Amplifier: Parasound HCA 1200ii 205 wpc
This setup provides all the SPL I need, I am curious is adding a second amp to drive the tweeters and mids will help SQ.
The goal is NOT to increase SPL but to improve SQ even at low volumes
edit : wrong thread, there should be a delete post in here .....
You are not getting close to the power limit available so compression is not likely. Splitting the signal does not help. Remember, it is 2V max so there is not much to begin with. At high volume, when compression is a problem with a single amp, the signal split trade-off is more than acceptable.
