Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
So I blew a tweeter in one of my KLH Model Six speakers. I have two Smaller Advent fried egg tweeters that I have been meaning to sell. Would one of them work in the KLH Six? Looks like both are 4 ohm. Thanks!
There is a relatively easy way to find out, which is to try it. I wouldn't suggest sawing and screwing to mount the Advent tweeter - tons of masking tape would do for a quick check, and would leave no tell tale marks if you decide to stick with a replacement correct tweeter (which aren't expensive). At the same time, it would rule out a dead capacitor, which is often the real culprit when a KLH tweeter seems to have given up the ghost.
Thanks, all, for the invaluable advice! I will try one out to see how it sounds and determine whether it could be a capacitor. If it sounds good, I would probably want to replace both tweeters with the SA versions.
