Xover Advice
elwood127
Hey all, I built some diy cabs using a JBL LE14A LF, a JBL 2412H HF and a 6inch Cerwin Vega PM7H Midrange (from model SE-380) with a JBL N110 xover. The cabs are 36 x 18 x 13 and have an internal volume of 1.5 cf after insulation. They sound great but one never knows if they could be better without test gear. I'd like to rebuild xovers and wondered if you had any suggetions on better values for my setup? The woof specs are 30-1300 hz but were straight through on the original Lancer 55 network. No specs on mid or HF. 41 watt SU-7300 supplying power. Please look at N110 schematic and see if any improvements could be made to better serve this speaker combo. Thanks.
No specs available, but called "Directivity" horns on the Goldwood website, implying that they do require HF Comp.
