SO I had the intermittent phono problem on the Yamaha C-4 -- one channel dropping out. After reading the threads I narrowed it down to a single wafer on the phono section. After reflowing the solder on all those small wafer PCB connections, I got phono to remain solid. Then I reflowed all the solders on all the other wafers. I also dexoited all switches.
No crackles, hums, buzzes, on any sources or switches. Looks good??
However, there is a 2 dB lower volume on the right channel (semi-technical measurement). This can be "compensated" by setting the balance switch to the right 1 o'clock position. Only the preamp does this -- other sources to my power amp and switching channel inputs/outputs shows the preamp has this.
The consensus (recruited family members) is that for the preamp all sources are doing this.
Is this a problem? Do I just set the balance switch right-wards and call it a day? Nah.....
Please, comments welcome!!
