My Yamaha C-50 has a strange problem when recording from phono. When I set the "REC OUT" switch to phono, I am only getting sound in one channel. This switch is to select the source that you want to record from. All other sources are fine.
I have checked everything else - connections, different decks, tape 1 and 2, phono 1 and 2. It is definitely an internal problem in the preamp. It seems like something in the internal circuit from the phono to the tape loops. I have already cleaned the relays and the switch that controls the (rec out). It is possible that further cleaning will be required.
Does anyone have any suggestions on where to start?
