Hello,
New to me Yamaha CR-840.
I know this issue has been discussed, but I wanted to post my voltages and see if I have a bad IC 704 powerpack or if I should be looking elsewhere. The unit powers on, but the relay fails to engage.
I used the CR-640 schematic since it showed expected voltages.
Test Points
TL 0.2 VDC
TR 34.7 VDC
IC 703 (all VDC)
10. 3.52
9. 34.7
8. 0.236
7. 2.06
6. 0.835
5. -0.402
4 -1.57
3. -0.188
2. -34.8
1. -2.92
IC 704 (all VDC)
10. -8.08 (variable)
9. 34.6
8. 34.7
7. -8.05 (variable)
6. 34.5
5. -34.5
4. -23.6
3. 34.7
2. -34.7
1. -35.6
If it is the powerpack, any recommendations on a replacement? Should both be replaced at the same time?
Thank you,
Greg
Test Points
TL 0.2 VDC
TR 34.7 VDC
IC 703 (all VDC)
10. 3.52
9. 34.7
8. 0.236
7. 2.06
6. 0.835
5. -0.402
4 -1.57
3. -0.188
2. -34.8
1. -2.92
IC 704 (all VDC)
9. 34.6
8. 34.7
7. -8.05 (variable)
6. 34.5
5. -34.5
4. -23.6
3. 34.7
2. -34.7
1. -35.6
Thank you,
Greg
