Ugh! Thanks for the clarification Hyperion. There are so many things to consider in these substitutions. I did the math on 85W and realized just how much current these amps can drive. Seeing all the challenges finding replacements, I'm never going to throw one of these away, just in case I need it some day.These are obsolete, and the contact current rating is poor at only 2A.
Nice try though.![]()
If you don't cut the pins off (and drill the board instead?), you will have 2 pairs of contacts (much better) for each channel instead of one pair....
This is correct, there are 2 relay contacts per channel on the AU-717's F-2663 board.Actually, I was under the impression that the AU-717 board was drilled for 2 pairs of contacts...
Maybe I was getting slightly confused about which contacts were to be cut off, or not - obviously it is the two inner NC (normally closed) contacts - as you say.This would defeat the purpose of a relay since the amplifier output would be available through the center pins whether the relay is closed or open!
The MY4 relay has 2 pairs of contacts for each channel (much better) instead of one pair.(the MY2 relay has 1 pair of contacts per channel).
The AU-717 board is drilled for 2 pairs of contacts - whereas the AU-517 can use either MYx relay providing the appropriate pins are cut off - thus the AU-517 is only using one pair of contacts per channel.
BTW: Regarding cutting pins off a relay - measure twice - cut once.
This post has been edited to remove any incorrect or confusing information.
Get an MY2-02-DC24 for preference, but MY4-02-DC24 will be fine also, (can cut pins to fit).i have sansui au 517,, i want put back relay to board ,, what kind type relay for this amp ?
https://industrial.omron.eu/en/products/MY2-GS-24VDCwhat difference between MY2-02-DC24 with this one MY2-GS-DC24,, can i use this one ?
SpecificationsThe relay terminal pins on the MY2-GS-24VDC are not for direct PCB board installation; they are used with "plug-in" relay sockets.
