Update: Found an Analog Discovery 2 measurement error after posting the first test results here a while back. The external 5V PSU has to be used to get accurate measurements on this amp. Updated results are in Post 9.
This amp was built probably back in the 1990s by the South Florida Audio Society. The Analog Discovery 2 measurements can be found here (now know these results were erroneous).
The amp hits 2% THD at about 2.4 watts and 5% at about 3 watts using 8 ohm dummy loads. That seems like poor performance to me for a push/pull EL84 amp. There is a good chance the OPTs are rated for 4 ohm loads.
Found what looks to be the right schematic here on AK, but it is pretty hard to read when printed. Anyone have a clearer version suitable for printing?
Pics of the amp are attached.
