Pioneer SX-1080 FM Issue
Pharssa
AK Subscriber
My Pioneer SX-1080 has an issue with FM. In FM mode there is no sound in the right channel / speaker. FM stereo light and signal meters work fine. Tuning alignment also seems to be okay. AM and all the other inputs work fine as well. Only way to get sound in both channels in FM mode is to either change Stereo mode to Mono or turn on / press in FM MULTIPATH switch / button.
I had opened a thread in the vintage solid state forum to get some help and did receive some to diagnose the issue and had tested that there is no sound at pin 21 in the tuner board.
http://www.audiokarma.org/forums/showthread.php?t=554887
Then I found a thread where Mark (markthefixer) has helped someone with a Pioneer SX-980 having issue with FM.
http://www.audiokarma.org/forums/showthread.php?t=164693&page=2
Following that process, I tested the sound in and out at PA3001, PA1001A and PA1002A chips in the tuner board and found:
1. Sound at pin 6 in PA3001
2. Sound at pin 2, 4 and 5 of PA1001A
3. Sound at pin 3, 14, and 12 of PA1002A
4. No sound at pin 5 of PA1002A
5. Sound at pin 19 of the tuner board.
6. No sound at pin 21 of the tuner board - this is the right channel.
I also noticed that sound / volume level was same at pins 3 and 14 of PA1002A (and I believe also at pins of PA1001A and PA3001) but volume level was higher at pin 12 of PA1002A.
Is the PA1002A gone bad or could this be something else? Any suggestions on the next steps?
Thanks,
Replace the 4.7uf 16v cap coming off of pin 5- C70 and see if sound comes back.
This is just a guess of course, could be a bad chip- those caps are original so it might be bad.
pin 12 WILL be louder, it is an amplifier with muting. Pin 5 should be just as loud as well.
It doesn't look good for the pa1002a... sorry...
It's a hard chip to find. 40 plus bucks...
I can consider replacing it. Where can I find one? Is replacing the chip easy, given that I am completely new to soldering; but I can follow directions?
Thanks,
For the benefit of all who are looking for Pioneer PA1002A chip, I found a brand new. It took a while to get it from Hong Kong/China. Not sure when I will be able to put it in and test it but here is a picture.
Hopefully it is the real deal.
I am also hoping that it is a genuine part. You never know about the sellers and the stuff coming from there; but it looks okay.
edit: On closer comparison with the one in my 1080 it looks slightly different (ignoring the letters after PA1002A); so my doubt about this being not genuine has gone up.
edit: On closer comparison with the one in my 1080 it looks a slightly different (ignoring the letters after PA1002A); so my doubt about this being not genuine has gone up.
Japan. Broker that bought up large lots of extra unwanted / obsolete parts precisely for this purpose (well, larger quantities than onesies twosies, but they DID sell to us)
we have gotten a few, they are new old stock. 4437 or 4438 (i don't remember exact # right now and no time to dig it out) is the real chip without the custom pioneer markings. Toko or something...
I have seen identically marked 4437/8's IN untouched and working 1980's (and others).
don't worry...
don't worry...
Finally got a chance to try the new chip. Replaced the old chip with the new one and it worked; So it turned out to be a good part as Mark had said. The issue is resolved. Time to enjoy FM radio.
Thanks everyone for ideas and help.
