JonL
Lunatic Member
I purchased a Thorens TD125 at a yard sale a couple of months ago. It had been in disuse for many years. It was dirty, had some damage to the veneer, was missing a headshell, and was reported to "not work." After much internal debate ("Do I really need another turntable? Do I really need another project...") I paid the $20 asking price. Here's what I brought home:
A quick look confirmed what I had hoped... the unit "doesn't work" because there is no belt. The motor runs fine without any noise.
I disassembled the unit from the plinth and found various household items to support it. This is not easy. The turntable is heavy, and there are no good places to grab it to pick it up out of the plinth. It's unwieldy and difficult to find places to support it when out of the plinth. To get it out of the plinth, the bottom cover must be removed. Then there are two wood screws holding strain reliefs for the power and signal cables. Finally, there are four slotted hex head cap screws that go up from the bottom through mounting blocks on the plinth into the main turntable chassis.
Here's a view of one part of the table inverted and supported on some large empty yogurt containers. (I like Divotdog's "jig" better than mine, but I had to use what was on hand.)
To separate the fixed chassis from the sprung main chassis and armboard assembly, first the tonearm wiring has to be unmounted from the fixed chassis. There's a strain relief and two screws holding down the terminal strip. That's it. There's also an "L" shaped piece of metal that attaches along with the terminal strip. I don't know what the function of this piece is, but I took the above photo mostly so I'd know how that piece went back.
After the wiring is free the two chassis may be disconnected. There are three very small locknuts that hold the suspension bumper assemblies together adjacent to the large nylon suspension adjusters. Once the nuts, washers, and rubber bumpers are removed the fixed chassis just lifts off the springs that stay on the sprung chassis. Now it's time for more yogurt containers and another clear workspace for the fixed chassis.
More to come soon....
