I bought a pair of 414Z in bartertown recently. They were fine for three weeks after arrival, and then last night I found both were suddenly rubbing pretty good (one has just been sitting around, one has been mounted and receiving test signals for measurement). I didn't mess with them last night, and just now when I went to check them out, I find the one sitting out is back to normal! The mounted one is still rubbing. A little pressure toward the ground, as it is currently oriented, allows it to move in and out cleanly.
What is a guy to do? I can't imagine these being very useable if they are going to shift in and out of alignment all the time. All I can come up with is to try reflowing the surround goop and see if that helps?
The surround goop doesn't have any big clumps/runs, but you can see that it is a little thicker on one side, along the inner edge of the surround.
I'm not sure if it's at all possible to judge the alignment of the pole and magnet without dissecting the whole driver? The three sections of the motor assembly are not perfectly aligned from the outside (~1/2mm off), but the welds look intact...
Starting to wish I'd chosen brand new woofers here. :sigh:
