Supplementing EchoWars' remark, bandwidth is very important when you "retransistor" a circuit. The original closed-loose compensation was based on specific bandwidth (f sub t) characteristics of the original amplifier transistors -- largely a function of internal collector-to-base capacitance. Each capacitance caused a frequency-dependent phase shift and the phase shifts summed to yield an aggregate frequency-dependent phase shift. The feedback loop was carefully tailored to generate an opposing phase shift so that, at all frequencies in the amplifier's passband, the feedback would remain negative -- and thus, oscillation would not occur.
Use of transistors with substantially different bandwidth can upset this apple-cart.
If you hook a scope to the amplifier at the output point (the collectors of the output transistors) you should be able to see any oscillations using a low-capacitance probe. Note that a typical AC voltmeter does not have sufficient measurement bandwidth to "see" an oscillation, say, at 700kHz.
Fred
