2270 BIAS will not Adjust below 45 mV...
I would buy a cheap hand held battery operated O-scrope, about 160$. With that and a schematic you should find the issue in an hour. Then you will have scope for the next time....
jk
Just spent my scope money on gasoline. Is there a cheaper fix lurking about?
There is no real substitute for an o'scope. Meters will tell you that there is a signal, o'scopes tell you what the signal is. If you are diligent, you can find a used o'scope suitable for audio work (20MHz or better, solid state) for less than $100. It can be your first re-cap project!
Tom
P.S. Stay home and fix gear. No gas required!:D
T.
