stuckinthe70s
Got a question for anyone who has experience working on Pioneer cassette decks. I just replaced belts and tires on my CT-F9191, that all went well but it still has an issue. When running in rewind, it starts out at high speed like it should, but then very gradually starts slowing down. Before it gets to the end of the tape, it will stop running all together. It does however run fine in fast forward.
During rewinding, if I look down into the transport at the spool end of the ff motor, I can clearly see that it's not slipping, the motor just slows down until it stops, as if it's run out of guts. Just for reference, I also replaced the pulley on the ff motor, and while I had it off, I gave the motor one small drop of oil.
I disassembled the transport again tonight just to check things out, and everything else appears in order, I didn't find anything that seems to be tight or loose. I'm suspicious of the motor itself, but why it goes in ff mode and not rw, I don't know. Does this sound like the likely culprit, or should I look for something else? Anyone with experience please let me know. I'd like to get this deck operational again to see what she'll do.
Cleaned some of the controls tonight and did a test recording. Works well. I would not want to take a DC motor apart--even with the post shown here. These motors are a pain to work on. My Teac is much easier with its AC motor. Its like their RTRs. Take it apart and oil it. No brushes to mess with.
