Does smaller getter flash mean less hours?
As a matter of fact, the size of the actual flash component is usually smaller than the end of your thumb, and sometimes even just as small as the USB plug itself. The shape and size of the drive itself is merely a design factor, not a technical one, and has no impact on capacity. Also, if you are encountering issues with getting it to work, you should check out this USB flash drive article that describes how to fix a non working drive.
were not talking about PC storage devices. were talking about the silver inside of tubes when theyextract the gas.
I started reading this and went... :headscrat ... Oh, I get it! Computer "flash drives"!
I think this was a "generation gap" moment. Like when I told a young kid I liked to listen to vinyl records and he said, "Oh, you mean those huge, pizza-sized CD things? I saw one of those, once!" He was referring to a Laserdisc, and was proud that he had seen such antiquated technology. He'd never even seen a BLACK vinyl disk, and hadn't a clue, when I started explaining what they were!
Getter flash: scroll down and read "H" here: http://www.vacuumtubes.net/How_Vacuum_Tubes_Work.htm
In fact, you might want to read the whole page.
:o I had no idea what "Getter flash" was...I had seen it, but always kind of just called it "that chrome stuff on a tube", man...I thought I was doing well in the vintage stuff, still have alot to learn. Thanks for the link:yes:, it is somewhat difficult to find pages that have alot of information, without alot of needless stuff. I'm just getting started in tubes, which in all honesty are more antiquated than vinyl. Shame more people don't remember vinyl except for "those large cds"...then again, I grew up with vinyl (mothers collection), so what do I know.
That being said, I don't think the size of the "getter flash" matters, since it only picks up stray oxygen, in very little amounts. The only difference would be the look of the tube itself.
I have a tube that has a graphite-looking layer on the inside, I wonder if that layer serves the same function.:scratch2:
Getter flash receding can be an "indicator", but nothing more. Many tubes that were "critical application" in the day, had red lines on them that when the getter receded past, the tube was changed out. I may have one here someplace.:scratch2: Ah, I do, here ya go. The red label says " DANGER- When glass shows clear imediately above labels edge REPLACE TUBE".
A getter flash that has clearly receeded often does indicate a tube with a lot of hours on it. I've mostly observed this effect on power tubes, and occasionally on driver tubes that were run really hard. I don't recall having observed much difference in the flash on small signal tubes in other applications.
I thought getter flash was...how to say this... sort of like a 'burn mark' on the inside of the tube.
Meaning, I thought all tubes, during the process of being manufactured were "flashed" and the byproduct of this residue (smoke, if I may) was deposited somewhere. Sometimes on the top of the tube, sometimes on the side.
As a deposit, in a vacume no less, I would have expected it to stay put much like soot in a chimney.
Are you tube experts saying that getter flash is "dynamic" in that, it is consumed or deteoriated over time such that it ...how to say 'evaporates'??
I guess I'll ask more point blank... is getter flash a residue from the process of being manufactured or is it a deposit that is to be depleted away as the tube accrues hours?
:scratch2:
It's a deposit that absorbs molecules in the envelope. These molecules for the most part, come out of the internal structure of the tube as it is heated.
+1
I notice this a lot on 7591, 6550, 6L6 tubes.....
The 7591 is probably the best example out there of how gettering fades away. I think it probably has something to do with the "special" plate material that tube uses. Either the coating, or the metal itself was supposed to conduct heat in a way that eliminated hot spots, thus allowing the tube to be run "harder" than most comparable power tubes.
Ain't THAT the truth! (well at least on vintage 7591/7591A's)
A lot of new production 7591's probably won't last long enough to have a substantially noticeable gettering change.
. . Falcon
Some tubes simply had smoked glass. I have a few RCAs with that mostly-opaque graphite-colored glass.
I think that the carbon (graphite?) coating in some tubes had something to do with suppressing or capturing rogue electrons or some such. Have to look it up as memory fails me here.
mike
mike
Makes alot of sense, though I think you are right about it being carbon, since graphite would be conductive, I was just trying to think of a way to describe the color. "Rogue electrons", great term, there, its a miracle tubes work nearly as well as they do.
Actually it was probably graphite then because I think the idea was to dissipate charge build up on the envelope.
mike
