If it's not the 8" driver, it has to be the crossover. The first thing I would do is replace that 47uF electrolytic cap with a new one. Of course, this means you'll have to do this in both crossovers. It could also be a resistor or a cold solder joint, but I'd start with the capacitor.this is the problem speaker and crossover...it is making a weird harmonic ringing type of sound on vocals...heres pics
8" woofer, i think is working properly.
i installed another 8" i had sitting around and it also emits the scratchy ringing sound?
any ideas now?
That's great. :thmbsp: However, I'd still replace those 20 year old electrolytic capacitors while you have easy access to one of them. Old electrolytic caps can go out of spec as they age and send low frequency information to the tweeters causing them to blow. Those are Philips tweeters and they probably aren't very easy to find like the Vifas used in later DCM Timeframe and Timewindow models.After opening the cabinets i may have found the problem, if this sounds possible?
the cabinet had damage in the area below the woofer which i believe was channeling pressure and sound through the tweeter...
i have filled this bad spot with hot glue and it seems to have cured the weird buzzing or wooshing sound.
:thmbsp: Glad everything has worked out. Another happy ending for a pre-merger set of DCM speakers.UPDATE: Changed out the 47uf cap in the crossover, and things are sounding VERY good.
This was the main problem with the speakers...low frequency was leaking into the tweeters and causing distortion...
The new foam looks great. :thmbsp:Wrapped them in their new foam socks today...looking and sounding GREAT.
These really are a unique and nice sounding speaker.
Next...logo badges???!!!!!
