CDX-1030 Inside pictures
EricC
Not the best picture but more can come if people are interested.
Edit: Attached front shot.
Finally got my turn on the stereo to hook it up. It sound pretty nice to my ears. I connected it to the SX-1250 and 5012s. Need to get the BX-1 to Rob for some work so I can connect it to that system.
I'm curious as to what is the CDX -1030? What type of component is it, and does the CDX - 1030 a nomenclature of the series of a particular brand?
It uses Yamaha's S-Bit DAC (Single-Bit) witch runes in 18 bit, the analogue side is done in class A and the player is member of the massive 10 kg+ elite. A realy good CD player.
MSRP in 1990 was $700.
The CDX-1050 I had followed the 1030 in the pic, essentially the same player but with slight improvements.
I'd be interested in know what areas are improved. I am watching one on Ebay right now. What about the 1060? I have a CDX-1120 on its way which most seem to agree build quality wise was only behind the CDX-10000 and CDX-5000
Don't forget the CDX-993 which too had an excellent construction and it had Pro Bit instead of S-Bit.
The CDX-1060 was the last in the line of super players starting in 1982 with the CD-1 and ending with the CDX-1060 in 1992 (it was sold until 1994). It had an MSRP of $800, even today they still catch a good price on e-pay only the CDX-1120, 2020 and special players like the CDX-5000 go for more.
Unfortunately Yamaha dropped there CD-P's from the American market in the early 90's so many Yamaha CD-P's were newer sold on the US market.
As mentioned earlier the 1030 uses the S-Bit DAC, where the 1050 and 1060 uses the S-Bit+ DAC. The main improvement lies in the DAC where the + stands for the added I-PDM part (Independent Impulse Density Modulation) Witch give the player better performance all over. The difference between the 1050 and 1060 is much smaller, I believe the 1060 is a tweaked 1050. The Yamaha engineers took the 1050 and said “how can we improve this without making a new design", the result is all kinds of small tweaks where the draw is the most eye catching. It resulted in a player that performs just a bit better than the 1050 (In my eyes it also looks better).
And then there is the lost child; the player that dropped from the sky, the CDX-993. It came out of nowhere, the super line of players ended in 1992 and then 6 years later in 1998 suddenly Yamaha made a new (and the last) super player. It started with the new Pro-Bit DAC in 1994 (YAC-514) developed for the CDX-880, then the engineers were allowed to make a player witch would take this DAC as high as it would go (and properly as high as Yamaha thinks 16 bit 44,1 kHz CD quality will go).
About the Pro-Bit I have to clarify, it is not instead of the S-Bit+. It is on top of the S-Bit+. The signal coming from the S-bit converter is run thru an intelligent selection where the Pro-Bit part applies one of 20.000 algorithms to up sample the signal to 20 bit dependent on the sound pattern. PRO-Bit stands for Precise Reproduction of Original Bit.
An interesting thing about the CDX-993 is the name, it IS a super player and normally it would be named CDX-xxxx. But the weight of the player drops just below 10kg (9,6 kg), so it was not given the name CDX-1093. If the reason is internal politics (I think the player was designed by Yamahas English design team) or just a simple rule of the 10kg I do not know, but it is a small mystery.
I am listening my first pro-bit dac and it sounds pretty good to my ears. The unit is a CDC-775
The DAC was already 6 years old when the CDC-775 came on the market and I believe they still use it today!
The sound has an analogue feeling, kind of soft and quiet in low passages.
Actually it still amazes me how analog my CDX-1050 sounds, I do have an Accuphase DP-70 but I still keep going back to the Yamaha from time to time.
Here's my recently acquired CDX-1030. I've been needing a "good" CDP, and I am VERY happy. I really am amazed at how much more I get from this thing; so steady and warm. Best $75 I've spent in a long time:thmbsp:
Just stumbled on this thread.. Hey Eric.. Still loving this player... :thmbsp:
Nice to see pictures of it without opening it up.. :D
BTW.. how ya been, haven't seen you around much...
Yamaha1,
Please tell us more about the Accuphase. This has been very esoteric to me and never had a chance to see it in person nor audition it. What laser does it have and what opamps do they use? A nude picture will be great. thanks in advance.
This is an old thread I dug up, and I realized that when I did.. however, if you notice under Yamaha1's name, it says banned, so I don't think you're gonna hear from them.
