Three Speaks
Zilch
Curve Junkie
Sunday fun at Zilchlab -- Baby Advent II, B&W DM305, and JBL Northridge E30:
attachment.php
Details:
Curious... What's with the precipitous drop at ~110-120Hz? Seems common to all of the speakers.
That's a room node at the mic position for that frequency, and the reason we do the nearfield bass response measurements shown in the individual curves. For those, the mic is placed 1/4" from the center of the dust dome or phase plug and port opening, swamping any room reflections.
Nearfield bass response reflects performance with one boundary of reinforcement, i.e., 2-Pi alignment, and thus exaggerates the low bass response somewhat if the speakers are to be used in freespace, i.e., away from boundaries, as the 1-Meter RTA and sinusoidal measurements are taken. By evaluating both, you can tell how the bass will sound in different alignments relative to the higher frequencies.
Here are the quasi-anechoic on-axis high frequency (above 200 Hz) measurements for the three:
attachment.php
I see. The green trace appeared, at first glance, just to be the LF response (I was assuming woofer+port combined).
When the Ultra Zeros are complete, I'm going to want to get them spec'd out. Too bad you're not closer! Mind taking a trip to Minnetundra?
The B&W (Green) appears to have the highest sensitivity overall in this group. :yes:
Specially designed to kill the JBL mid-bass hump?
Well, I (and Wiredbecker) have the advantage of also knowing which speaker sounds best.... :p:
