Stevesmullen
Well-Known Member
Hey Guys.
I just aquired a Mint SX-1250 that has supposed distortion in the Right Channel.
The Unit came from a shop that the customer declined the work,the work order parts list states that it needs (4) 22,000mf 80volt caps and some misc caps.
I didnt bother to hook speakers up to it yet just hooked up the dim bulb tester first to make sure that nothing was pulling to much current (all was okay there)
Plugged the unit in to wall power with all the covers off and tested voltage at the 4 main cap terminals.
The left side checked good at +65 and -65 vdv but the right side had -42 and +65 vdc.
All the caps are just starting to leak but didnt make a mess yet.
"Mark" Can I power up the Amp with the 4 main caps unplugged to test for supply voltage?? I WONT DO ANYTHING without approval first
I would think that it would be okay to do with out a load because if Im right the caps are there to store power for the OPs.
What are the part#s for the 4 Caps and what other caps should I replace to freshen this unit up?
Thanks Steve
Thanks Steve
