I can't use those readings.
I took a lot of time on those last HUGE posts, getting ALL the example numbers consistent, and making sure ALL the language was consistent, leaving nothing open to misinterpretation. A careful examination of the posts should have left nothing to chance...
Then, I posted a picture of what to measure, right down to the lead color.
THERE IS
NO GROUND REFERENCE FOR THESE READINGS, and 1.895 means you are measuring something wrong. A reading of 1.895 between Q4's collector and Q6's collector would NEVER allow ANY bias curent to flow, as well as indicating very serious problems with D1, D2 & VR2.
Also the readings were expected in pairs:
markthefixer said:
markthefixer said:
(first number is pot at min, then second number is pot at max)
1. NO OUTPUT TRANSISTORS CONNECTED UNTIL I SAY SO, AND IT WON'T BE IN THIS POST.
2. crank VR2 to MINIMUM OHMS
3. put one voltmeter lead ON Q4's collector and put one voltmeter lead ON Q6's collector, TAKE READING (3.41V)
4. put one voltmeter lead ON Q9's base and put one voltmeter lead ON Q10's base, TAKE READING (2.30V)
5. put one voltmeter lead ON Q9's emitter and put one voltmeter lead ON Q10's emitter, TAKE READING (1.110V)
4. crank VR2 to MAXIMUM OHMS
3. put one voltmeter lead ON Q4's collector and put one voltmeter lead ON Q6's collector, TAKE READING (3.82V)
4. put one voltmeter lead ON Q9's base and put one voltmeter lead ON Q10's base, TAKE READING (2.50V)
5. put one voltmeter lead ON Q9's emitter and put one voltmeter lead ON Q10's emitter, TAKE READING (1.300V)
NOW assemble the report:
"number one channel 3.41 to 3.82 , 2.30 to 2.50 , 1.10 to 1.30 "
NOW GO TO THE OTHER CHANNEL:
NOW assemble your SECOND report:
"number two channel 3.41 to 3.82 , 2.30 to 2.50 , 1.10 to 1.30 "
