Post #40
<snip>
parts list post:
http://www.audiokarma.org/forums/showpost.php?p=1709685&postcount=72
problem is, the 1250 in that thread was never completed, so the substitutions were never tested.
<snip>
IN that post, the recommended replacements :
drivers
2sb630/2sd610 to-220 bce 200v 2a 25w 4mhz hfe:80
two: 863-MJE15032G to-220 bce 250v 8a 50w 30mhz hfe:70 $0.87
two: 863-MJE15033G to-220 bce 250v 8a 50w 30mhz hfe:70 $0.87
versus:
(q9, 2sd610) 512-KSC2073TU_Q npn to-220 bce 150v 1.5a 25w 4mhz 40-140hfe $0.53
(q10, 2sb630) 512-KSA940TU_Q pnp to-220 bce 150v 1.5a 25w 4mhz 40-140hfe $0.54
drivers
edit: use the KSA / KSC's not the MJE's - Vbe turnon is a bit lower and results in too much bias at times 4/25/09 mtf
drivers
two: 512-KSA940TU_Q pnp to-220 bce 150v 1.5a 25w 4mhz 40-140hfe $0.54
two: 512-KSC2073TU npn to-220 bce 150v 1.5a 25w 4mhz 40-140hfe $0.54
Looking at the specs, we MAY just be able to get away with using the Fairchilds PERMANENTLY, other than the 1.5 vs 2 amp current of the 2sb630/2sd610/s. I will calculate....
The 30 mhz on-semi's worry me, in regards to amplifier stability, while the fairchilds are right on at 4 mhz.
Steve:
1. Upon Calculation, Use the fairchilds permanently, the only theoretical limitation could be at the absolute high power end of the usage, an sx-1250 is rated :
160w into 8 ohms which is 35.77v across the 8 ohm speakers, giving 4.47 amps of current
200w into 4 ohms which is 28.28v across the 4 ohm speakers, giving 7.07 amps of current
assuming a worst case gain of ten at 7 amps for the outputs, they will only need less than an amp to make rated power, and that is at 4 ohms, where the danger to the outputs comes in the form of power dissapation increased by sub 4 ohm loads... just the place we would LIKE to limit things a bit.
worrying about 1.5 amps versus 2 amps is not indicated (silly actually).
2. RE: R25, seeing different polarities at the ends of a resistor is NOT an indication of a problem, the zero volt point would be somewhere IN the resistance element, all that matters is that the current is flowing through the resistor. If the current wasn't flowing, the opposite polarity voltages would be a LOT higher. This is a book learning/calculating part, not a winging it part. It was the result of the Q9 / Q10 mismatch/unbalance (dead/damaged/leaky is STILL mismatched)... looking closely, the effect can be found to a far lesser degree all over the amp, at all the pnp/npn push pull stages.... the end result at the output being zero is what matters as long as the internal conditions are not extreme enough to upset OTHER functions (like it did with the idle current).
