Tucker99
Successfully replacing the filter caps in the 2215 I cheerfully got busy on one of the 2216s that I purchased in the same bundle.
Cleaned and lube'd the first of them .... now it is making music but with a buzz on both channels. Thought that I would start by replacing the filter caps only to discover that the 2216 seems, for me at least, more difficult a job than the 2215 was.
My issues are two-fold: a) the large gray 4700 uf cap referrer to having a 'dummy lug' ....does this mean that there are three pins holding it in place as I cannot get the cap to move, a b) [which might in part be affecting the cap removal] the cap wires are bent through the hole in the circuit board and my soldering iron is struggling to heat the wire sufficiently to pull the cap out. Is this my total lack of experience or is all the heat from the iron just being sucked into the cap? Is there some obvious trick to getting these big old caps off the board?
I note that the two smaller 2200 uf filter caps don't appear to have a dummy lug, assuming that the main cap needs to have that third pin addressed.
Thanks
John
Thanks
John
