rob29
I recently picked up a full Toshiba 335 set. Preamp works beautifully but the amp has been slightly scetchy since I brought it home. I was originally getting a full 35VDC at speaker terminals but after some proding I found that there was a bare wire that was rubbing the power supply cap pins.
I kept testing and even dared to hook up some speakers to it and found that I was getting a sporatic pop from them every few minutes. Figured it was a bad connection so I deoxited all the terminals and switches and did a complete recap excluding large 10,000uF power capacitors. Power circuit is at a steady 35V throughout.
After this I am getting a sporatic DC in the Left channel that jumps to around 1V and Right chan is staying at a steady 70mV. It seems that I am getting some sort of leakage DC that is going through the entire left channel. Strange thing is that after unit has been on for about 10 minutes with 2 dummy loads, the DC goes down to 30mV in left and stays at 70mV in right.
So far I have deoxited, recapped, resoldered connections, doubled output ground wires, and still have been unable to get this amp to the way I want. Does anyone have some troubleshooting advice on where to look or a schematic or service manual available? There is a pot on each channel that is labeled Idle and a + and - idle terminal as well. Is there any general value to adjust this too?
Thank you all for your help.
