if the quiescent current is too high why not adjust it with the preset ?, why are you changing the bias diode ?
The replacement transistors should work.
At this point, I suggest to check the amp without drivers, and without power transistors. This will tell you if the differential input stage and the voltage gain stage are working properly. You should disconnect any load on the speaker side.
But, to perform this test, you must connect one resistor (10k) from the point where the base of TR7 is actually connected, to the point where the emitter of TR11 is actually connected. You must also connect a resistor of the same value (10k) from the point where the base of TR9 is actually connected to the point where the emitter of TR13 is actually connected.
Do the same for the other channel.
Why?, may you ask. To close the feedback loop.
You should be able to adjust the bias trim pot to have ~1.9V to 3.7V from the collector of TR5 to the anode of D3, AND nearly 0V at the speaker fuse terminal. Do you have this?
So which transistors to I need to remove to test? Only TR 11,13,7,9 in right and same in left correct?
solution 1, replace all the transistors (with new uns) and start again
solution 2, take it to someone who knows what their doing
I will be taking out the ossiciloscope soon and will be trying to see if there are any components that are leaky. This is quite a pain but that is what makes troubleshooting fun.
Do you mean I don't know what I am doing?
Solution 1 is for those who dont understand how circuits work, and solution 2 is actually a defection.
rob29, I see that you are serious about taking this on. ....and you do have the experience level to do this. Amplifiers are like big op-amps. Treat them like that when doing things such as "closing the loop", determining gain, etc. The push-pull stage is kind of a bolt on but a lot of op amps have complementary output stages, like discrete power amps.
Tools of the trade:
VariAC
Switchable current limiter (lamp)
AC current meter
If the bias lets go, this setup will prevent collateral damage. You'll be able to bring stuff up slowly while watching the current draw. Sometimes full throttle with fingers crossed isn't the preferred method.
When the Lamp glows, sumpin ain't right.
I will be making a variac I guess
The resistors that were beside both pots, R41 and R42 were both brown-black-brown which is 100ohm. I pulled the first out and measured 1400ohms across it, second one almost 2200ohms. Replaced with 1/4W ones but I just thought about it and I will put in some slightly larger ones. Too bad I didnt get it before my order.
So I tested the HFE of the main driver transistors. My PNP transistors have a gain of 44,48, and 50. My NPN transistors have gains of 66,66, and 67. Will this cause a problem with the push-pull configuration of the amp or should I be ok with using two 66 and the 48,58?
