Speaker Measurement Thread
Skywave has loaned me his copy to try, so this is timely.
First question regarding M-Audio Fast Track Pro -- that's USB, and I assume it must require high-speed 2.0, no?
Knowing my computer, do I have that? How do I determine if so?
Ken Kantor suggested something else, I believe, in another thread. I'll have to look that up.
I'm going this route because I doubt the audio "card" in the computer is up to SoundEasy (SE) requirements. How do I determine that? Has to be full duplex or something...? :dunno:
If I remember correctly your is not usb 2.0. Right click My computer> properties> Hardware> Device manager> system devices Do a "print screen" ( button on keyboard ) paste to a word doc and email it to me. I will pm you my email. I will see if we can ad a device driver for 2.0. I think it was a VIA chipset. If new enough it will be able to do this. Otherwise I have a 2.0 pci card I can send you or I could probably get you a newer machine for next to nothing :deal:
No the sound is not full duplex. It is better to have a dedicated card anyways.
I was just thinkin it was time for an upgrade for the Zilchter anyways!!:D
Looks like it is 2.0, but Fast Track Pro (FTP) doesn't appear to require that:
http://www.m-audio.com/products/en_us/FastTrackPro.html
What it DOES require is Windows XP (SP2), whereas this is a Win2000 machine.
Wiredguy is setting me up with another XP computer like the one in my office, so that will work.
Just to be sure I understand this, FTP is in effect a full duplex external sound card with phantom power mic preamps, which connects via a standard USB port, and SE will also run under its requisite WinXP operating system?
Tascam US-144
Not a deal breaker, but other elements being equal, I think I'm willing to pay a bit more to have separate balanced and unbalanced outputs and not have to kerfutz with the headphone jack.
The original Tascam discussion is here:
http://www.audiokarma.org/forums/showthread.php?t=211565
Not a deal breaker, but other elements being equal, I think I'm willing to pay a bit more to have separate balanced and unbalanced outputs and not have to kerfutz with the headphone jack....
Yes it is full duplex. simultaneous input/output operation. Think of it like a hard line phone. As I understand it you need more than 2 channels to build 3way and higher crossovers. Otherwise a 2 channel unit is all that you need. Newer sound cards are duplex and there may be updated drivers for yours as well. I usually stay away from stock sound cards as I am "unsure" about there qualities.
Ok If the machine you currently use CLIO on needs XP Let me know I have about 12 OEM copies left.
Also replied to your email with details of the other machine if needed.:yes:
Yes, gotta move up to Fast Track Ultra (FTU) and USB 2.0 for 24/96.
Can SE can even take advantage of that, i.e., does it have a 48 kHz measurement option? Not sure if we can trust these mics up that high, even.
CLIO standard is 18/48, so even with USB 1.1, FTP is delivering higher resolution than CLIO's A/D, assuming SE uses it.... :dunno:
http://www.audiomatica.com/clio/overview.htm
I am not sure if it can or not. Still tinkering.....:scratch2:
I ordered V16 today should be here by the end of next week.
I now have V16 and will be trying to climb the learning curve.
It looks as though I need to build a pseudo infinite baffle to measure TS parameters.
Zilch do you use this method or do you have a WT?
Both WT and CLIO use free air impedance measurements to establish T/S parameters. To get Vas, they require using either added mass or a calibrated test box.
A large baffle is useful for response measurements so that drivers may be compared under the same conditions. Those conditions are not the same in an actual speaker construct, so I don't bother with that, having plenty of cabs here, i.e., I do response "in-situ," primarily, as that's where I've gotta get, ultimately, anyway, as filter optimization must be done in the final alignment.... :yes:
Yeah, SE can measure using 48kHz sampling. Note, the mic doesn't have to go up that high, the computer is just sampling at that frequency.
FWIW, I use an Audiotrak Maya EX. It's a USB soundcard with 2 RCA inputs and 6 RCA outputs. It's also not available anymore unless you can find one on ebay. It seems to work well with SE as far as I can tell.
edit: another very helpful tool is the tutorial written up by John K.
No, doing the XP computer upgrade.
Did look at the M-Pro USB dealie, though.
[Need $200.... ;) ]
Thanks Ray for your input. I did get John's help file currently reading trying to learn how to use this software. It does appear that it is very full featured.
I asked Santa for the Smith & Larson Speaker Tester for Christmas. Will have to wait and see what shows up under the tree. :scratch2:
Zilch
How are the er umm loops going?:D
I have started with Soundeasy got some Impedance curves. Had to stop and re read the cookbook. I also got D'apolito's book that went right over the top.:no:
Mrs. Claus has pardoned me and allowed me to get the Smith and Larson Speaker Tester.:banana:
http://www.woofertester.com/stproduct.htm
Wayne has said good things about SL products and it looks like it has a very good XO simulator.
I should have this by next week. They custom test/calibrate each one that goes out the door so I am hoping for some fun soon.
I am more of a hands on kind of guy so to be able to make good measurements and then apply them to known good configs will help my learning curve quite a bit.
BTW hows Soundeasy working for you? Anything good bad? What version are you using.
V15. Install instructions begin with the word "Invoke." :tongue:
Also downloaded HOLMImpulse and Bagby's PCD.
[This is gettin' messy.... ;) ]
