Pete B and Ken Kantor are looking at the cheap in-line phantom powered USB preamps. Pete has discovered that the one he bought doesn't have sufficient front-end attenuation to permit nearfield measurements without overloading, but that may be because he wants to maintain max S/N ratio and plays the DUT at high SPL.
When I saw this:
It's a Neutrik Minilyser (with companion Minirator). Came with this mic and 20db attenuator for nearfield measurements. Of course the mic has an AA battery in it, so it doesn't try to run 48VDC through the H-Pad...
Most times phantom power is fed right to the XLR via a pair of resistors, so if you need to add a pad it has to be between the XLR and the actual input amp (or transformer). I have an external 48V phantom power box with XLR in and out that would work just great in this kind of high SPL situation, just plug the pad in on the output cable...
(BTW, thanks for reminding me to take the battery out of the measurement mic, it's been in there for 3 years at least, I was worried about it leaking, but couldn't figure out how to get it out last time I was using the RTA, found the little push-button this time!)
When I saw this:
I believe 120 dB is the max for any of the common ones; if you're measuring jet engines, high SPL mics are available for a substantial upcharge.I was running 200W into a 12" sub and wanted to check the speaker's max SPL distortion. I was able to just pull the mic away and see the clipping go away.
On order, Pete.... :thmbsp:Anyone tried this, it is low cost and has phantom power.
I'll tell ya, reading some of those ECM8000 links remind me of what an OCD crowd audio techies are!
