Hartsfield help
CaptainTrips
SO I am new here. I will probably get banned for this but I just got a Hartsfield for FREE. It looks amazing but I am unable to get sound from it. All I hear is a humming. I probably look like a newbie asking this but I am so I think I can ask away. I am just trying to fire this beast up and hear what it can do so if anyone has suggestions, that would be greatly appreciated.
I'm no JBL expert, but others will chime in shortly. For the rest of us... can you post some pics, please?
Your problem is probably not the speaker, it's in the MC60 monoblock. Are there any techs near the LA area, that are familiar with mac gear?
Not only are you a very blessed man, receiving a Harstfield for free, you also have excellent taste in Stephen King novels. Pictures, please!
Ummm... what MC-60? There's nothing in the OP about an MC-60, but the electronics would certainly be the first place to look.
my hartsfields always worked great. you're plugging it into the speaker outputs of yoru amp right? not the ac in your wall?
LoL - just kidding. they DO have ancient crossover components - if it's just humming then it's likely shorting out or something and killing your amp. disconnect it immediately, remove teh crossover from teh back and recap everything ($$$) or at least remove each component and check it for basic operational ok-ness then replace each component. you know, conductivity, do the caps actually work like caps (irrelevant of them being accurate in any way still). the level control(s) may need severe cleaning.
but a hum sounds really bad to me - a speaker can't hum, but an amp can hum if it's speaker output is shorted out or something like that.
but also, if your amp just hums anyway, the hartsfield is INCREDIBLY sensitive and will show up any issues with your current amplifier and preamp (and sources).
still - I'd say disconnect it and check it for basic operation. and while you have the crossover out, try driving the main horn and hte woofer individually directly from your speaker output to make sure they make music. neither needs a crossover, just don't throw a lot of bass or volume at the main horn without a crossover on it of course. and if yours are the later or modded 3-way versions, don't even consider running the tweeter (called a ring-radiator in this particular speaker) without a crossover on it of course or it'll blow up.
if the speaker's toast but one or more drivers are ok, you can still sell it for a lot of money.
I sold my hartsfields for about $4000 or $5000 each I think a few years back. I just needed to change... I didn't have the space any more. it's sad, they were amazing, but I didn't have the gear to drive them properly either (not a lot of power needed, but definitely a lot of quality needed that I didn't have back then).
Yeah, I should have specified. He told us in chat that he got the MC-60 and Hartsfield speaker that were left behind in a house he moved into. So, I think he's going to need help in that area.
As with any high-value JBL collectible, I advise you not to do anything like mess with the crossovers. Collectors want original and mint, working or not.
If you ultimately find the crossover is defective, build or buy a suitable substitute, or run it active.
Did I say leave the original alone?
Holy cow, JBL and Mac tubage left behind? Cripes, what a find.
I would suspect the tube amp rather than the speaker here. Try the speaker with another receiver, and if it works, don't plug in the Mac again until it gets worked on. You could damage very expensive parts.
I'd also suggest that the Mac not be run until it, too, is fully checked out. Likely these were purchased in the 50s at the same time. If this is the case, then they're 50+ years old. You wouldn't fire up that 1959 Thunderbird and barrel down the road at 80 mpg, right? Same for top quality vintage audio gear, too.
Cheers,
David
That Hartsfield and MacIntosh amplifier should sound absolutely wonderful. Since they don't, as you know, something is very wrong. The only thing I might try if I were you would be to hook up a known good amplifier to verify the JBL is in good order. Then, you will know if just the amp is suspect. You could also hook up the Mac to a low value (cheap) speaker to verify its performance, but I would almost be willing to bet money that the amplifier definitely needs to be sorted out by a tech.
IMHO that amp is way too valuable to power up again if it is already humming. That possibly means electrolytics in the power supply have already failed, so you're just asking for a power tranny or output tube burnout.
Sorry I am busy bouncing between work and stuff lately. Pics finally!
Hartsfield
Backside
The cabinet
McIntosh
