Well bit of a story.......................
So I got it all together, I measured the OP's and supplys and made sure I was in good shape.
Double checked my wiring, and on the way found some discrepencies in the schematic, anyway I was good to go.
So I started to wind the variac up..................now remember, the driver board I have in this amp came from the later version 7700. I looked long and hard at the powersupply section because I was a bit worried I might take something out in the tuner section. It says in the bulletin that the digital boards from the tuner section are not interchangeable...........the first thing that happened was a capactitor on the tuner board exploded, so I stopped and unplugged the tuner board and the digital display board. Ive got some work to do finding out about the tuner supply voltages I think. They must have changed something when they changed the tuner section in the later version............Thats fine I can handle that.
Back to the amp. So I made a VBE multiplier to regulate the bias current. Now in theory I had to wind the trimmer fully clockwise to obtain minimum bias..........so what did I do? exactly the opposite of what I should have.
So as I wound up the variac everything was looking good and I had two meters on each channel looking at the Bias current........all good I kept winding it up........and then when I got to about 80% line voltage, the bias took off and ran away very very quickly, the OP's got very hot, I couldnt understand what was going on, and before I had time to turn it off I heard the powersupply growl as the OP's shorted out.
Great!! The last ones in the world well vitually you know what I mean....
So while I was at work today I was looking in our old stock of spare parts for amps we do not own any more, and I found two bags of Toshiba transistors. They are 2SC3281 and 2SA1302 (complimentary black NPN/ green PNP).........so I downloaded a datasheet and discovered they are very similar to the 2SC2581/2SA1106 used in the Sansui. The Toshibas are higher voltage higher current and faster devices.
So I grabbed the bags of devices 20 in each bag, Great score!!!
They were originally for the Carver PT1250 amplifiers we had 15 years ago, the amps are long gone now so I was able to score these OP's.
I got home and loaded them in, I then discovered my error with my trimmers, I corrected that and measured everything up and started to wind up the variac.................same thing monitoring the bias on both channels, this time we had success, it ran. I set the bias at 6mv for starters, then I realised the relay haddnt turned on, so I looked at the DC, oooppps!! 15VDC on the left channel, the right channel I managed to get down to 0-2mv, but the left channel, I quickly traced it back to the JFET, I took it out and put another one in, and we were off, I got that one down to 0-2mv as well.
I need to modify the VBE circuit a bit to get a better adjustment sensitivity for the bias........but its in the ball park, I could afford to run it a bit higher with these OPs, they can handlw 30% more current than the sankens........
It sounds great on my test speakers, I have to run it next to the other one on the JBLs to compare, it was throwing out 42V from the output before I could see any clipping on the scope.........................Awesome, might end up eclipsing the other one!!
So I have to find out what is going on with the tuner section, and there is a bit of a hum in the right channel, originating from the preamp. Could be caps. This poor amp has had such a hard time with its heart being ripped out all those years ago, but its coming back to life bit by bit.
To add to everything the digital display actually works on this amp!!
I also want to LED the panel lamps, nice blue ones or something like that, but we will see, Ive got to get that tuner working..............
I didnt take pictures but I will see what I can do in the morning...............
Its all good!! You guys over there in America should be able to hear it if you put your head out the window...............
