jbryant_77
Ok my first bread board amp build ever and it plays music
and sounds nice:drool:... I read and learned all I could over the past year about building tube amp circuits here on AK. I started collecting parts about 2 months ago and with alot of help from an oldtimer learned to build a power supply. I decided to use a scheme from boozehound labs for a single ended 6v6-6sn7 amp. The circuit was modded just a bit and I droped the 6sn7 for a 6j5g and used a 5v4g for the rect. The 6v6 is triode straped for about 1w and with the right speaker sounds magical. Running a small 2 way 8" with a horn I can get pretty lound volume from it befor it starts to distort.. Well here are some pics and I will continue to update as I drill and finish the chassis. Thanks for reading
First pics are of the mono build to see if it worked:scratch2:
Time to try stereo
Ill do my best to answer any questions and keep the thread updated
Jason
and sounds nice:drool:... I read and learned all I could over the past year about building tube amp circuits here on AK. I started collecting parts about 2 months ago and with alot of help from an oldtimer learned to build a power supply. I decided to use a scheme from boozehound labs for a single ended 6v6-6sn7 amp. The circuit was modded just a bit and I droped the 6sn7 for a 6j5g and used a 5v4g for the rect. The 6v6 is triode straped for about 1w and with the right speaker sounds magical. Running a small 2 way 8" with a horn I can get pretty lound volume from it befor it starts to distort.. Well here are some pics and I will continue to update as I drill and finish the chassis. Thanks for readingFirst pics are of the mono build to see if it worked:scratch2:
Time to try stereo
Jason
or to advanced
to recieve a comment. Ohwell Ill just post about tubes and rebuilding magnavox amps from now on...:tears:
