audiodon
Addicted Member
This is the story of Fisher 500-C #55172R.
What goes around comes around.
In the late winter of 2006, I purchased a 500-C off ebay. This Fisher was sold out of Amherst, Massachusetts, so I elected to pick it up, with Amherst being about a hour and a half west of where I worked at the time.
While I was there, the seller said, "I have another one that you can also buy, but it has no tubes and has not been turned on in years.
I bought it.
This is the story of that second Fisher 500-C, serial #55172R.
That one was dirty, with somewhat rusted transformers and a very dusty chassis. It had seen quite a bit of use too, having been used in a store, and the tube sockets were a dark brown color.
It spent two years in my garage.
When I finally had the time, and the inclination, and had collected some tubes, I brought it out, cleaned the chassis, removed and cleaned the front panel and dial glass, popped in some tubes and brought it up on a variac. Lo and behold it worked . . . and quite well, I might add. I'd used some marginal tubes but it didn't seem to mind. I did use my favorite line stage preamp tubes. Also, I threw in a quad of EH 7591s from an amp I'd bought from motorstereo.
So, I gave it new coupling caps, updated the multiplexer, and did everything but replace the electrolytic caps, including replacing the rectifier, first stage filter caps and replacing the diodes with hexfreds. I used a quad of K42Y PIO caps in the output. I also painted rustoleum black on the transformers.
Then I brought it into the shop of my favorite local ebay flipper with a pair of speakers and set it up for demonstration and sale. I set the price low because the restoration was incomplete and the tubes weren't the best.
Lo and behold the receiver garnered a lot of attention, including from AK'er gigbyt. So, I sold it to him, but with him being someone who would know the difference and deserved a fully restored amp, I told him I'd have to replace the electrolytic caps, and burn it in fully. I also put in some stronger tubes, knowing I'd make almost no money, but someone would put this amp that thrived on abuse to good use.
This was in the Winter of 2010. At the time I told him I don't don't work on gear in the summer.
In the late Spring, gigbyt came back and stated that the amp made noise sometimes, and only intermittently, on his Klipshorns. I told him that I don't work on gear in the summer but I had an integrated that was almost done he could use if he dropped it off.
Something was wrong with the first integrated gigbyt took so I had him take a second one.
I do have a picture of 500-C before I restored it, but it's on another computer and I'll have to add it later.
We can call the problem with the 500-C tube farting. It would be dead silent, and then there'd be some noise that was untraceable. After it sat for five months because it was not my work season, I was able to track down this difficult problem with help from AK'er sgmlaw.
So, gigbyt got his amp back, but his confidence had been shaken and he decided to sell it. He sold it on AK and had it professionally packed and shipped. That's where the trouble began.
http://www.audiokarma.org/forums/showthread.php?t=329919
Well, I've got it back on my workbench now, but with the holidays I won't get to it for another week. Here's some damage pictures.
I bought it.
