NoTransistors
Dual Turntables Super-Restorer
I have four full-size Dual. The two 1229Q have silicon caulking filling the underneath of the outer rim, where the balance weights reside. Also have tar-backed aluminum roofer's tape on the outside of the idler contact rim. The underside of the platter cannot be coated with anything at all, as there is a strobe disc.
My 701 has the caulking only.
The 1219 has the roofer's tape only, as I have been too lazy to caulk.
All have the perforated shelf-liner mat- black and 0.2" thick, which is close to the thickness of the Dual mat.
Even with all this, the platters still ring a bit.
Sooooo, now hold onto your proverbial hats.
I was in Marshalls with the ball 'n chain, and purchased a
13" silicon-rubber splatter screen. It is a China-made [like you expected Spain, Japan, Italy, or something like that] perforated silicon screen on a metal-reinforced handle.
The perforations are arranged in circles, which can make cutting easier.
I cut a circle to fit the way the shelf-liner mat fits [just inside the raised platter edge]. Then tried the thing ON THE LEAST-DAMPED 1219 PLATTER. Oops, too thin. But now, when you hit the edge of this platter, it has a much-reduced ring. Almost there... Wait- there is more---When it is applied to the already-caulked platters, it produces a true thud, an absolutely dead platter with ZERO RING! Yes, you heard me---ZERO RING. Next, I cut a pretty white mat from the thinnest liner in my collection. Put it on top of the silicon mat. Gave me the proper height, and a different sound entirely.
So, the cost was 12.99 plus tax plus the gas to take a gas-guzzling GTO out to Freeport and back to Brooklyn. I believe it was well worth the expense.
