Zonker92
All shiny and chrome
If you look at my signature, you can see that my 846B Valencias have almost the same components as Model 19s. The cabinets are kind of cool, in a way, since the baffles unscrew. So I'm thinking of making new screw-in baffles that are flush with the leading edges of the sides, and front-mounting the woofers in those baffles. That would look cool, reduce baffle diffraction and increase slightly the cabinet volume. All of which would doubtless yield zero audible improvement but hey, I like tinkering.
If I did that, for proper time alignment, I think I'd want to use a spacer to bring the horn forward, too. So ... would I want to keep the horn flange at the same relative depth as it has now, with respect to the face of the woofer? And for that matter, is the rear-mounted 846B woofer set to the same relative depth as the front-mounted woofer of the Model 19, vis-a-vis the horn? (I note that the Model 19 horn baffle is recessed but its woofer baffle is flush.)
I guess a simpler question is, does the Model 19 have correct time alignment such that, if I ever do this, I should simply copy the relative depths of the Model 19?
