When aliging voice coils I don't pay any attention to where the horn flares and flenges end up, the voice coils are the key. Regarding magnet front and backs, the horn driver has a throat so you want the magnet to pull the diaphragm towards it for forward excursion towards the listener so they reverse polarity, remember, a positve signal applied to L1 causes the diaphragm to move away from the magnet. The woofer voice coil sits on top of the magenet, so, + on L1 causes it to move forward towards the listener, confused yet?? :scratch2:
The magnet is still in front of the voice coil in both diagrams.
I'd love to see pictures of your risers, Mike. How did you finish them? As you probably noticed from my signature, I have the 902s, also.
Ricoh, somehow I always manage to start discussions that mess with your head, and somehow I always conclude that I'm the one who was truly confused, and you were right all along. Why is that?ara:
So I'm probably just going to mess things up even more, but anyway, on a normal woofer the magnet is behind the diaphragm. And the bulk of the magnet is behind the voice coil. A compression driver is the other way around. Or does that totally misunderstand your question?
The good thing about offsetting the 811 2" back from the woofer baffle is that you can always shim out to obtain a closer offset. From listening to mine, the 2" offset played best. I am using an active crossover and messed a bit with delay but found they sound best with the stock offset.
