Uncle Bambi
Funky Tut
I picked up a Sansui AU-317II recently that needs repair, and could use some guidance in how to proceed.
The first thing I did when I got it was to open it up and do a visual inspection. No obvious signs of fire/burning/physically damaged components, but the 5A main fuse was blown.
I replaced the fuse, put the unit on a DBT, and fired it up. The 100w bulb got very bright and stayed there, so I quickly shut it down. Obviously, something is pulling lots of current..... hopefully I didn't do more damage by doing something stupid.
I downloaded the service manual (which isn't much), and I'm in the process of pulling it apart to get a good look at everything. The output drivers are marked SONKEN 2SA981 and 2SC2261, and are socketed to the main board through a big heat sink.
I have limited troubleshooting experience, and most of that is confined to Pioneer silver series receivers. I do know how to read schematics, use a meter, remove/replace parts, etc., but lack the experience a lot of you seem to have.
So..... where do I begin? Is there a way to test these output drivers to see if one of them is bad? Can I fire up the unit without them in place to see if the DBT behaves better?
What's my next step?
