jazzzman
Auto Return Mechanism on PL-55X refurb log
My purchase of a PL-55X came through.
If I have done this correctly, a picture of the table should be attached (maybe in duplicate, I seem to be having a problem with the attachment function). Unfortunately no dust cover.
I tried it last night with the dl-110 I use on my PL-610 and it sounds great! I plan to change the electrolytic capacitors (there appear to be only 3, which are in the power supply circuit) clean the return mechanism and get a decent cartridge.
The table seems to have the same problem I have seen other PL-55 owners have noticed: On albums that have a narrower run out, for the last 5 to 10 rotations on the last track the tonearm bumps a little and a clicking sound can be heard. From reviewing the SM, it appears there is a lever attached to the tonearm that, at the end of an album, strikes an aluminum plate that pushes a plastic arm in a position to be struck by a pin on the underside of the platter. The pin causes the plastic arm to "kick out" which releases a plate that ultimately causes the tonearm to rise and return to the arm rest. My guess is that the pin bumps the plastic arm, but that the arm is not moving enough to release the plate for the several rotations. If the arm bounces back, I would expect it to cause the aluminum plate to rebound and strike the lever attached to the tonearm, causing the tonearm to bump. I suspect the clicking sound is the pin striking the plastic arm.
I hope that cleaning the correct parts will permit the plastic arm to move sufficiently on the first "bump" by the pin to activate the mechanism. One poster has suggested using isopropyl alcohol to clean the return mechanism. Does anyone disagree? Should I use a q-tip to apply it? Any other thoughts?
Thanks in advance.
****I have expanded this thread to include a log of my refurb efforts****
If I have done this correctly, a picture of the table should be attached (maybe in duplicate, I seem to be having a problem with the attachment function). Unfortunately no dust cover.I tried it last night with the dl-110 I use on my PL-610 and it sounds great! I plan to change the electrolytic capacitors (there appear to be only 3, which are in the power supply circuit) clean the return mechanism and get a decent cartridge.
Thanks in advance.
