A beneficial Technics tonearm mod that only costs $2.50...
cube-tube
I tried a little something today to see if I hear any difference and improve on the performance of the SL-1700MK2.
So far, I don't hear any negative results from doing this, and it did seem to "clean things up". From what I'm hearing on familiar records, this little mod has firmed up the lower and upper bass as well as refined the midrange and treble. Sound stage has definitely opened up more, giving the music and instruments more space to breathe. Imaging is quite startling! Vocals are more three dimensional, and I believe there's even more in the way of dynamics.
I honestly wasn't expecting this kind of improvement, if any really.
The mod consists of five #83 O-rings which are 1/2" OD and 5/16" ID. They're the chunkiest ones I could find that fit the tonearm tube. I got this idea from people putting heat shrink on these tonearms to help dampen them. Since I didn't want to put heat shrink on my arm, I figured this would also do the trick, if not do a better job! If it works on vacuum tubes, it should work on a tonearm too.
Adding these five O-rings added roughly 0.45g of weight to the tonearm, at least where I have them placed. I guess this could be "tuned" depending on where on the arm you place them. I kind of placed them randomly as to not create equal distances between them. My thought behind this is that if I placed them equal distance from each other, that might cause some kind of tuned resonance. I don't know, it sounds good anyway. LOL
In the end, I think this is a very worthy mod that's extremely easy to apply and remove with zero permanent alterations to the arm. Just a couple of minutes to put them on as well as remove them.
Anyway, enough rambling. Here's a few pics. Let me know what you guys think! And yes, I re-balanced the arm and readjusted VTF.
I've heard of this tweak before. Always sounded interesting. How did you settle on the number and placement of the o-rings?
John
I too have heard of this before. If I remember correctly it was decided to gently tap along the arm tube and listen for differences in sound to locate where to placement o ring. I think just one was recommended to use 1 ring. It was several years ago so I could be mistaken, but I do remember I read about it on Audiogon.
How did you put them on? Do they slip over the lock collar?
John
I just picked a random number and random placement. I didn't want to use an even number of o-rings and I thought that one or three would be not enough. LOL
It's a tight fit, but yes, they just slip/roll over the lock collar. I take the arm off the rest, make sure to NOT put any undue pressure on the arm, and brace the back of the collar as I slip/roll the O-rings on one at a time.
From the pictures your platter looks like it's high. Do you have the transport screws removed and have you adjusted the suspension. I've heard about the O rings before as well. I may have to try it on my arm.
cube-tube
It would be interesting if You could upload a couple of files from the o-ring arm, and the same from the stock arm. WAV files preferably.
gusten
Good eye! I actually placed three hockey pucks under the TT to "disable" the suspension. Before, it would bounce with even light footfalls in our 2nd floor apartment, ultimately causing the needle to jump. Disabling the suspension completely eliminated this.
Those look pretty cool on there regardless.
Maybe, but it sounds a lot better. :thmbsp:
How do you like the Signet TK7E and did you use a protractor or a headshell jig to mount it?
I used both the Technics overhang tool and a protractor. I really like the Signet. It's probably my best cart other than the Stanton 981HZS that I have. They're actually neck and neck with subtle differences between the two, with the TK7E being just slightly more analytical, just a tad bit stronger bass, a tad bit more forward midrange, and a tad bit more sparkle on the top end.
cube-tube
gusten
I'm not certain if I have a way of doing that or not. All I have is iTunes and Windows Media Player on my laptop.
Interesting thread. I had placed three on each of my arms/tables, spaced unevenly for the same reasons that you state. I have found only modest gains in sound tightness.
Rubber shrink tubing on mine. Made a HUGE improvement, no joke.
The only thing keeping me from trying that is the necessity of removing the collet. That means unsoldering the headshell wires and I hate soldering (because I stink:))
By the way, is that a marble slab on Sorbothane? How's that work?
John
cube-tube...
Is that a clamp or a weight you are using in the pics?
I have a Technics SL-1600 MKII and have considered trying a weight but the owner's manual says to never use a weight as it will damage the DD system.
cube-tube...
While on the subject of cheap tweaks, a 1" piece of fuel line on the spindle makes a great clamp.
