beatcomber
AK Member
I've done a bunch of arms. I may have done Beatcomber's arm in the photo too. Glen, correct me if I'm wrong.
Correct you are, Paul!
...Don't knock this technique until you try it.
....tape, no matter what kind you use is going to make some kind of mess on the tonearm that might be a bit of a PITA to clean off. Not to mention that it's covering the entire arm, so not really "tuneable"....
...Heat shrink tubing, once on and fully shrunk is nearly impossible to gt off of something as light and delicate as a tonearm. In order to remove it, it has to be cut/sliced to get off, risking damage to the tonearm...
A lighter will work, but I find a heat gun on low setting to start, then high setting, gives bst results.
As does removing the arm tube from the pivot section, the collet, and internal wire- which I do as I also rewire them. Removing as such allows for a more precise end result.
I also damp the arm tube internally with cotton. Kevin at KAB also uses cotton to internally dampen the arm tube.
Lastly, Kevin adds a plastic end cap with o-ring to the tone arm end stub. $4.99. I use this from Kevin, and I add expanding foam (two squishy ear plugs work well) into the end stub.
I finish with higher quality RCA cables.
The shrink tube, cotton, and foam ear plug material are a few dollars.
The tone arm wire and RCAs add around $45 to this, but I feel are worth the investment.
Nah, the weight of the rings by on a scale by themselves is what matters, if it matters to a given cartridge. A tonearm only makes a good scale if you put all the rings on the end right above the stylus and use a gauge under it.The amount of mass added to the arm with the five o-rings installed, if it correlates anything near what I had to adjust on the counter weight, is only 0.450g. So in other words, the o-rings added nearly half a gram to the weight of the arm. Either way, it didn't add any ill effects to the overall sound and performance.
Honestly, I don't know that I ever heard any resonance with the arm bare. I do know that after adding the o-rings, there are very noticeable improvements. That was something I really wasn't expecting, at least not so drastic.
If I were to test this improvement with strip of an electrical tape, where would be the most effective area on the tonearm to stick it to?
At one point, I've tried it at the bending curve area but it didn't seem to do anything.
Tape on the arm has no benefit IMO.
gusten
I'll be gankin' some shrink wrap from work tmw, but got inspired by this thread. I have a Technics SL1400mk2 and I took some of that really grippy rubber stuff that you can cut into sheets, sliced a piece slim and long, and wrapped it around the tonearm with a tiny piece or two of black electrical tape.
I just wanted to see what it would do.
I can now literally poke the top of the lid while playing, and almost NO bang is heard.
Damping that arm makes a huge difference, at least for me. Thanks for the tip, gentlemen.:thmbsp:
Those could be fighting words to some on here. :boxing:
After putting the o-rings on my tonearm, I am now a very firm believer in tonearm dampening. It works, and it works good.
Tonearm damping is very difficult and encourage to put pieces of tape on it doesn´t really help, as I see it.
gusten
...Tape on the arm has no benefit IMO.
gusten
Everything resonates at some frequency, no matter what the shape. And as far as I'm aware, nearly 99% of the tonearms out there, new and old are tubular.
