Well, I came across some rare M&K speakers, model SV-200B. Pretty dusty, but overall in great physical condition. The tags were clearly made for the SV-100B, but there's a 2 sharpied over the 1. I couldn't find a photo of the SV-100B's, so I'm not sure of the differences. I could only find very limited info on the SV-200, so I hope others might be able to chime in with more.
They're 40.5" tall and weigh roughly 50-60 lbs each. Each tower is made up of an S-2B satellite speaker (1" silk dome tweeter, 6.5" poly midbass) and a Volkswoofer 2-B (12" powered sub, 200 watts RMS).
So far, I've tested them and one woofer was blown upon plugging in the plate amp, even with no signal coming in and the bass level pot turned all the way down. It made a loud oscillating noise and blew the foam and dustcap open, even though it was only plugged in for about 2 seconds. The external fuse was fine still. The other amp/woofer seems okay, but the foam is shot. Both mid/tweeter sections work.
I'll have to pull the woofers and amps to get an idea of whats going on, but I'm no expert on powered subs or the M&K brand at all. If anyone has some ideas on what to look for, please offer them up. These should be a good project if there's a light at the end of the tunnel.
Here's a link to the restoration thread on these - https://www.audiokarma.org/forums/showthread.php?t=626741
