Replace that 12.5 cap. That should improve the mid range response. When I re capped my Qb's I increased the stuffing by about 25%. That tamed the bass boomy-ness.
I'm patiently waiting. I have a pair myself. They were my eye opening speakers. The tweeter is really something special. And the woofer takes some good abuse! They bring out detail in the music. I have a cd that sounds terrible on all my speakers...except the QBs.
Sorry progress has been a little slow. I had to drive out to LA last weekend...
I have used the sound coat mix on previous speaker projects.
I am replacing all the crossover components with new ones, thanks to Parts Express:
Whoa!! Those are some really fine speakers and you are pulling out all of the stops to get the max out of them! I am intriguer by the slurry. What are you mixing the sand into and what proportion? I have never seen this. Does it reduce reflection also or is it primarily to reduce vibration? Will it replace bracing? I cannot wait to hear about the results. The tweeter is the star of the show IMHO but that mid is some serious stuff too. Thanks for sharing this.
ROb
I assembled one full crossover, but when I tested it the Lpad was sticky and sound from the mid only came out at one position of the dial. Some glue had seeped into the potentiometer, gumming up the works. I'm too embarrassed to show the pictures. I ordered a new pair of 5 ohm 5 watt L-Pads from Mouser. I hope to get a little more progress this weekend. I have to get the house ready for the Thanksgiving relatives...
Thanksgiving is over; relatives are all gone; mass quantities of food consumed. Now back to silver wires.
I completed the crossovers. It's funny how the second set comes out much neater than the first:
Little touch up cleaning is due:
I'm going to test them right now.
I should have the Qb's completed over the weekend.
Cheers!
Mike
Here are the final steps to the Qb transformation:
Xover mounted in the cabinet. I used small wood screws in the corners:
Acousta-Stuff:
Installed drivers:
Re-painted stand:
Everything installed. I used a pair of newer EMIT tweeters. They have a larger magnetic structure and sound smoother to me. Also, one of the metal wire clips on the original EMIT had broken off:
I have to glue together one of the speaker grill frames and route out a curve on the upper left side to accommodate the flange of the new EMIT's. I purchased some dark black grill cloth to cover the modified grill frames. More pictures to follow...
So far, I'm very happy with how they sound.
:thmbsp:
Mike
