ibanez59er
Nice job, I too would like some more info on that paint and sand mixture. What you used and it's results.
Nice !! You did what all we Qb owners want to do some day
Please post listening impressions, and if you would do it again...
BTW, what is that small brown resistor I see on your crossover? My Qb have just 1 resistor:
Original:
https://dl.dropboxusercontent.com/u/1640933/infinity/bafles/nuevos/6_P1060617.jpg
After recap (tweeter by-pass not in the pict, but added later):
https://dl.dropboxusercontent.com/u/1640933/infinity/bafles/nuevos/8_P1060623.jpg
Whoa!! Those are some really fine speakers and you are pulling out all of the stops to get the max out of them! I am intriguer by the slurry. What are you mixing the sand into and what proportion? I have never seen this. Does it reduce reflection also or is it primarily to reduce vibration? Will it replace bracing? I cannot wait to hear about the results. The tweeter is the star of the show IMHO but that mid is some serious stuff too. Thanks for sharing this.
ROb
I am glad to see someone asssign importance to treating the cabinet. Thank you! Damping a resonance here and a vibration there really does make a difference in the end. I have used a similar 'goop', ReptiSand embedded in two-part epoxy. It does great on the back of driver frames, especially in recessed spaces that are just "made" for holding damping goop, like the back of a lot of tweeter faceplates. Another good one is sand in resin (like fiberglass resin that hardens via a catalyst). These are probably a bit trickier to work with than your solution, though. Have you ever tried Cascade VB-1X? It's not the cheapest stuff but seems to work well. The interiors of my RS-IIIa's are lined with it.
Very enjoyable read, sir!!
G~
Edit: If I may make one observation on the solder joint to the foil inductor....
It looks like you have folded or pinched the foil around the lead wire going to the caps, and then soldered that. Specifically, I'm looking at the last two photos in post #18. One technique that I think works quite well for foil inductors is this: poke a hole through the foil near the end using a pick or drill it with a small bit. Form a j-hook with the next wire, just like the ones you did on the leads going to the laminated steel inductor. Run the j-hook through the hole in the layers of foil, and then pinch it very tight with needle-nose pliers. Make it tight enough so metal-to-metal contact is gas-tight. This is the primary electrical contact area, and then soldering into the joint between the wire and the foil is 'icing on the cake' to make it that much tougher. Just a thought for the future...
Here I have the drawing I've used to rebuild mine:
https://dl.dropboxusercontent.com/u/1640933/infinity/pie_Qb.pdf
All measurements in centimemeter. Round to standard values, small differences come from the innaccurate CAD drawing.
The 1.2 cm dent should match the gap at the back of your cabinet.
Material thickness is 6mm .
