jeromach
With sufficient thrust, ducks fly just fine
(as a follow up of this thread)
I already have done repairs and recaps on a couple of SU-8088's and SU-8099's, but the 8088 I just finished is the first one I gave a rebuild all the way.
Where in the past I did not exchange the large filter caps or transistors and diodes, in this rebuild it's all been done.
All electrolytics have been exchanged as well as the major part of the transistors and diodes (just not those that were ok and for which no suitable replacement could be found).
The major switches (those known for causing trouble) have been dismounted, taken apart, thoroughly cleaned, regreased, remounted and built in again. A rather tedious
and time consuming job, but the only way to avoid trouble in the next coming years.
The other switches and the pots have been carefully cleaned and regreased, now working without any scratching and moving smoothly again.
Of course all chassis and body parts have been cleaned too.
DC offset and bias have been adjusted to the correct values.
The 7,5 volt pilot lamp has been replaced for an 8 volt lamp.
On the scope the amp now shows 37 volts at the speaker outputs (both channels at an 8 ohm dummy load and at several test signals) with the volume at maximum, which calculates
to 171 Watt peak power (and a lot of clipping
). So, just before clipping it's 26 volt which is 84,5 Watt and that is nearly exactly as given in the documentation. This power level is
reached at a little more than 50% on the volume pot scale.
But, these figures is not what is most important, much more important is how this amp sounds. I never thought an 8088 or 8099 was on par with for instance one of the early
Luxmans, but I need to say this particular 8088 did impress me. It really sounds a lot better than before the rebuild and not just only better, it really sounds good.
The rebuild is a lot of work (if done properly), but for sure worthwhile. I'm glad I did it in full.
Some comments on the thumbnails;
1. The amp after the rebuild. Just only still with the original filter caps... or is it?
2. Apart from the resistors everything has been replaced.
3. The top and right connecting points of this double resistor are the bias setting points, not every manual explains this.
4. Clean and brightly / freshly coloured board, I like it that way
5. Speaker selector / protection / relay board. Here I found the only mistake in the service manual. The specially ordered 22uF Nichicon Muse bipolar cap was a
waste of money, it appeared fitted was a 220uF bipolar. Luckily I had a Panasonic 220uF in stock, the blue one and only non Nichicon (except for the filter caps that are Panasonic too).
6. Aha, they are new after all
) but obviously still very far from what you're hearing now.
