I always wanted a pair of these, and Retro Stereo had a very nice pair that I talked him out of at this year's AK Fest. We played them while we were there, and my impressions were that they are a bit muddy, and what highs were present, were so narrowly focused that if you weren't sitting in exactly the right position you might as well turn the speakers to face the wall, 'cause you aren't gonna hear the upper octaves.
I brought them home, and after I got some projects out of the way so I'd have some time to really evaluate them, I hooked 'em up to the Kenwood KR-9600 for an extended listening session. Unfortunately, this session was rather short, as one tweeter wasn't working. No fooling with the tweeter level control made any difference. As I was getting up to shut the whole system down, a 'pop' came from the errant speaker, and the tweeter started working. OK...so I've got an intermittent tweeter. Not exactly a tear-jerker, since I'm pretty unimpressed with the stock Seas 87H tweeter anyway.
Apparently, the recommended replacement tweeter is the Seas 27TFFC. The horizontal dispersion plot of this tweeter just didn't impress me, so I looked at other Seas models, and decided on the 27TBFC/G, which also has a metal grill to protect the tweeter dome, simlar to the original. I also ordered a couple of Solen 5.1µf 400V film caps to replace those sad original electrolytics.
The stock 'crossover' for an A25 is nothing more than a 5µf non-polar electrolytic cap to protect the tweeter from the bass. Nothing more. This further enforces my belief that the choice of tweeter is highly subjective, since there isn't a complex network matched to the tweeters' parameters. I've also heard others talking about the stock inductor for the woofer...this A25 has none. The woofer is run wide open, and only natural rolloff is relied upon.
Did I mention getting the grills off of these sucks? :bash:
Anyway, parts came in yesterday, and I pulled these apart and replaced the crossover cap, and also replaced the wiring to the woofer (the stock wiring must be 24ga...tiny stuff). The tweeter wiring was left alone. Cleaned the tweeter level control with some ProGold, and reinstalled all the drivers, itching the whole time from the nasty ancient fiberglass insulation. Ick... The new tweeter lines up 'close enough' with the stock screw holes to get it installed, but the hole in the cab had to be enlarged in two places to make room for the new tweeters' terminals...a 5 min job with a file.
Now the speaker sounds like something worth listening to. The bass and mids were always decent, but the highs now join them. The new tweeter is a perfect match...not compared to the old tweeter, but to the old woofer and crossover. With the tweeter level control all the way up, the speaker is a little too bright. With it set to what is labeled as 'Normal', it is just about perfect.
These things aren't never gonna rock the house, but are great for a bedroom or den setup. While they do an amazing job, especially considering the tiny size of the original voice coil and magnet on the Seas woofer, they haven't come close to changing my opinion that modern speakers kick the snot out of 98% of the stuff built before 1980 But -- with these mods done they are more than listenable. Certainly I'm of the opinion that the Seas 27TBFC/G is a very good choice for replacing the original tweeters.
Cost of mods? About $80, a couple of hours, and a lot of itching.
