“Superman” Speakers
DaBigTookie
A008A1A9-2005-432E-AF78-8FF1A037E35C.jpeg BF18D05F-80B7-4CDA-9487-B841B846B62C.jpeg 8C9B2B96-1B0F-40F6-B176-862EACE8823F.jpeg 33625F6C-DF2B-4180-9BFA-3BE36206D95E.jpeg 90B850DD-AA8B-4713-A662-6FA4B585597E.jpeg 385ED2A3-6CDA-4D5B-B79F-2B74F1BC8BC9.jpeg 9D3675FF-95FD-426B-8E48-5FD42B9B1B97.jpeg 95CAD0DB-4400-424E-B254-E2E53035E5A3.jpeg D3DE4076-1B8D-4E64-B8AC-E370EE2B152A.jpeg 5B82A7FA-2FD3-4723-BFD4-E7E15D9EFD8B.jpeg A008A1A9-2005-432E-AF78-8FF1A037E35C.jpeg BF18D05F-80B7-4CDA-9487-B841B846B62C.jpeg Hey guys, just wanted to see if
anyone knows what these speakers are?
I referenced Superman because of the obvious top of cabinet picture design.
Looks to be from the late 70’s just because of the look.
Bi-directional design:
Each top half houses (2) 8” drivers, (2) 3” mids, (2) 1” tweeters
38” H x 16 1/2” W x 10”D
45 LBS each
Those are so cool. It looks like someone took inspiration from the DCM Timewindows. They look too finely finished to be prototypes. I love how the chamfered edge shows off the oak grain. And the handles, and access ports! So sensible! And the transformer/autoformer in the crossover, probably for level-matching the drivers. Someone was a DESIGNER!
How do they sound?
How do they sound?
They actually sound very balanced and open.
Running them on Musical Fidelity A300 integrated right now, will try them on a Jolida Integrated tube in a week.
They look very homebrew to me. (Or built by DCM lol) Plywood front panels vs MDF the woofer cutouts look jigsawed. The backing plates for the woofer screws. Crossover parts mounted to the underside of the oak top. Mid driver cutout obviously used a simple smaller drilled hole before driver big circle cut to accommodate the wire terminals. Maybe a side project from someone in a small speaker shop? Very cool. No port. Was there any fill inside the cabs? With no port/transmission baffles are they a little bass shy? I think they are pretty attractive. Print a large stylized Superman "S" and tape it to the top?
Some speaker fill inside the cabinet, bass is somewhat what you’d think it be with no port, has a classic sound and fills the room easily.
