Can you give us a link for that product?
https://www.amazon.com/gp/product/B00QVB6NE4/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Thanks I don't like Amazon so I did a search with their title. Found this The O Ring Store.
I think the little plug rests atop the big one, directly under the dome.
. When I had oem samples on hand for the 044ti and 035ti, I didn't have the right durometer scales to measure these very soft materials. Did the next best thing and tested against other materials using my finger
The small piece is 6mm DIA., a fairly hard foam, doesn't seem like it's intended to compress. The larger 22mm DIA foam is extremely soft. The small hard piece sticks to the magnet first, then the softer one over it which creates a little more of a dome shape (which is pretty hard to create otherwise from a sheet of foam).Thank you @SaturationPtI could see that working for the domed magnets but I don't think the little nubbin will boost the large foam enough to do it's intended contact on the flat magnets.
Edit:
Gracious eBay seller reports that the old style used a smaller soft disk on top of the larger, replaced with the kit. Seller also said to leave screws loose and adjust fitment in the gap until there's a clean sine at 2-3Khz.....Now if I only had a scope...
Audio geniusing is HARD.
I'm loving this hobby, in the garage with music playing and my hands and mind occupied. (I come from a long line of tinkerers)
![IMG_20180911_145955569[1].jpg IMG_20180911_145955569[1].jpg](/forums/data/attachments/1153/1153184-f35f417572e856b99e0717dc51890b7d.jpg?hash=819BdXLoVr)
@milo63, you never said if you tried your band saw yet. Regular blades with teeth will rip apart the foam. DoAll can supply a custom blade that is ground like a razor blade, great for cutting foam and rubber. Just use gloves when installing it.
BillWojo
